Mixning different ap
i have à system with Nebula and six Nwa 50.
considering upgrading with one or two wax 650 S or wax 640S.
are both these two ap:s compatible with nwa 50 and able to manage with nebula in a mix mesh system.
what are the pro and cons between the two different ap:s.
I know the different between regarding 6 E but I am not sure about the other pros and cons.
Hi @saltet ,
It's great to hear that you are considering upgrading your network with the Zyxel WAX650S or WAX640S-6E. Both APs are compatible with the Nebula system and can be managed alongside your existing NWA50 APs.
To know about some differences between the two models that might influence your decision, please refer to this thread.Zyxel_Judy
Hi @saltet ,
Thanks a lot.
After reading the thread you advise me to read a will go for 650S.
I think that the mix environment I have will not utilise the 6E for some years.
Best regards0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
