Firmware update section Nebula
jacob123
jacob123 Posts: 12 image  Freshman Member
Zyxel Certified Network Administrator - Security First Comment Sixth Anniversary
edited November 2023 in Nebula
Could we please swap panes in firmware mangement or maybe allow users to change it, it would save a click everytime :)
  • Zyxel_Kay
    Hi @jacob123
    The current design is meant to streamline the firmware upgrade process based on device types. To better understand your specific needs, could you please provide more details about your use case?
    Kay
  • jacob123
    Hi Kay
    I have a wish and my colleagues as well, everytime I setup new devices, I go to firmware mangement, and I have to click devices, because it starts on overview.
    It would save a lot of clicks, if theese to where swaped :)
  • Zyxel_Kay
    Hi @jacob123
    Understanding your specific use case helps us assess the feasibility of such a change.
    To delve deeper, could you provide more information about your usual workflow in firmware management? Are you mainly checking for firmware versions, handling separate device firmware upgrades, or is there a specific aspect of the firmware management process that you believe would be more efficient with the tab swap?
    We greatly appreciate your input as it plays a crucial role in our efforts to enhance the overall user experience.
    Kay
Nebula Tips & Tricks
