Alert for flapping devices
Thorsten
Thorsten Posts: 9 image  Freshman Member
Ideas master First Comment Friend Collector Fifth Anniversary
edited April 2021 in Nebula
i think it would be nice to send an alert if the AP is flapping.
  • RUnglaube
    RUnglaube Posts: 135 image  Ally Member
    5 Answers First Comment Friend Collector Third Anniversary
    What do you mean by "the AP is flapping"?
    Is it AP or wireless clients?
    "You will never walk along"
  • Thorsten
    I mean the AP f.e. because the router has some connection issues.
  • CrazyTacos
    CrazyTacos Posts: 53 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    This should already be possible through the alert setting. Just set the "AP goes offline" alert to the shortest time. That should allow NCC to notify you of constant flapping.
  • WebberIT
    WebberIT Posts: 53 image  Ally Member
    Ideas master First Comment Friend Collector Second Anniversary
    I would say probably to change the router is the real solution... shouldn't that cause other problems on your network?
Nebula Tips & Tricks
