Interface Lan on Nebula Firewall can't ping to internet.
Hi All,
I wonder that why on Nebula firewall , i can't ping/traceroute from lan interface to internet.
Example:
I config interface lan1 ip is: 192.168.13.1/24 and assign to port 3.
Using default policy.
I try ping from lan1 → 8.8.8.8 → Fail
I try ping from client(192.168.13.2/24 ) which connected to port 3 → 8.8.8.8 → Success.
I have checked log but nothing relate to traffic from lan1 → 8.8.8.8
Is this a feature of nebula?
Or my config is mismatch somewhere?
Hi @Bearle,
When you ping from lan1, you can only ping the IP addresses in lan1 or the remote site of site to site VPN.
Dear Emily,
Do you have any document about this behavior? I would like to clear this :D
Due to some reason, i just only check connectivity by tool on Nebula gateway. But this behavior prevent me to do that.
Bearle
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
