Router Zyxel EX3301-T0 firewall, rule priority
Could you say anything about how the router Zyxel EX3301-T0 works with respect to its firewall functionality? I have a specific question:
If you set up Security > Firewall > General, level to "High", and create
an Access Control Rule that drops FTP traffic from LAN to WAN; what happens?
-- Will the text "Only local network traffic and LAN to WAN service
(Telnet, FTP, HTTP, HTTPS, DNS, POP3, SMTP) is permitted" have priority? Or ACL?
I e will FTP be dropped?
I couldn't find the answer in Zyxel's manual (470 pages), about which rule that has priority.
you can use protocol , Security>Firewall> Protocol
The user guide available at https://www.zyxel.com/uk/en-gb/support/download and https://www.zyxel.com/uk/en-gb/products/dsl-cpe/dual-band-wireless-ax1800-gigabit-ethernet-iad-ex3301-t0
says the following:
"Your customized rules take precedence and override the Zyxel Device’s default settings. The Zyxel
Device checks the source IP address, destination IP address and IP protocol type of network traffic
against the firewall rules (in the order you list them). When the traffic matches a rule, the Zyxel Device
takes the action specified in the rule."0 -
Thanks for info.
I'm not impressed of the firewall. Each rule consumes 5% of the memory, and I probably need to write more than 20 rules…
The firewall also lacks the ability to group IP-addresses in each rule, it seems.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
