ZyXEL ES-1528
Hi @Sythesy
Here are a few steps you can take to troubleshoot:
- Check the Switch's IP Address via the Router's DHCP Table
The switch may have already obtained a DHCP-assigned IP address from the router. To find the current IP address, check the router's DHCP table. - Isolate your switch
There's a potential IP conflict with the router, kindly disconnect your switch from the router temporarily and connect it directly to your PC. Try accessing the switch using its default IP address. After successful access, consider adjusting your switch's IP settings to either a static or DHCP-assigned IP. You can then access the switch using the updated IP in subsequent attempts.
Feel free to reach out if you have any further questions.
Kay
0 - Check the Switch's IP Address via the Router's DHCP Table
Hi @Sythesy
Kay
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 455 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 436 News and Release
- 91 Security Highlight
