CA Certificate for SSL VPN on USG 310
Is there a step by step tutorial how to set import an SSL cert from a CA given the following:
- SSL VPN is working, clients are connecting
- Port is (just an example): 8888
- Clients use SecuExtender 4.0.4.0
- I already have a xyz.domain.com registered and used for port 443. I also have working CA cert for the xyz.domain.com.
- Do I need to register another domain, say: vpn.domain.com, and obtain a separate cert for it, or would the import of it to USG 310 work?
Thanks.
Hi @DeeZed
Thank you for inquiring about this question. You don't need to register another domain to address your USG 310; you can still use xyz.domain.com to address it. When you want to establish the SSL VPN connection, you can input the domain name(xyz.domain.com), username, and password.
Thanks.
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 481 News and Release
