[Release Note] Nebula Security Gateway Series - Phase 6 firmware has been released!
Zyxel_Moderator
Zyxel Nebula Security Gateway Series
Release Note
December, 2018
Firmware Version on all models
Zyxel NSG50 - V1.25(ABHP.3)
Zyxel NSG100 - V1.25(ABEA.3)
Zyxel NSG200 - V1.25(ABLD.3)
Zyxel NSG300 - V1.25(ABOS.3)
New Feature and Enhancements
1. Add NSS Analysis Report. (Pro-Pack feature)
2. Support active/passive Failover mode in WAN load balancing function.
3. Support WAN Connectivity Check by default gateway.
4. Support Anti-Virus function in NAT rules.
5. Skip reporting “IPSec ping checking successfully” log to NCC to reduce spam log messages.
1.Symptom:
Policy route and firewall rule doesn't work.
2.Symptom:
DHCP option with HEX error.
Condition:
a. GATEWAY > Configure > Interface addressing > Interface > LAN2 Edit > Extended option.
b. Add new “Extended options”.
1. Option: User_Defined
2. Name: User_Defined
3. Code: 43
4. Type: HEX
5. Value: a123456789b1234567
c. LAN2 interface can’t save the DHCP option.
Content Filtering and SFP Issue on NSG50:
1. Symptom:
The HTTPS domain filter of content filter doesn't work in NSG50.
2.Symptom:
NSG50 SFP with 100M throughput can’t work.
Condition:
a. SFP set 100M throughput configuration.
b. SFP link status always down.
Notes
- To all users when upgrading Nebula devices, please make sure your device is connected to the control center and internet.
- During the upgrade process (notice the LED will flash in red rapidly), make sure the power is not inturruped or disabled, in the unlikely event of this happening, you may have to perform the upgrade again.
Nebula Forum Moderator
The NSS reports is great. I would love to see a report that shows a list of IP addresses each client is having a conversation with and the amount of data that has been transferred.0
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
