Cannot Login to USB FLEX 50
I am having some difficulty in login to console. the user name field is disabled. On inspection I can see that the input field is 'readyonly'. It's having a default username as support. But I have been asked to use 'admin' and pwd '1234'. Any suggestions would be greatly appreciated.
Hi @bbtv ,
The firewall is in Nebula mode, password is at Site-wide > Configure > Site settings > Local credentials. Please use local credentials to log in device local web gui.
Unfortunately, I don't know the exact cause or exact solution. I can only suggest that your unit contains a custom firmware and that you may have to install a default firmware to solve your problem.
Hi @bbtv ,
Thanks . It solved the problem.
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
