FLEX100h VPn to ATP doesnt Work
SamuelJucker
VPn Config with Wizard, VPn Tunnel OKAY, but no traffic. What ist the Problem?
i have found the Problem. In the VPN Remote fails the Subnet. With 192.168.X.X/24 it Works. Only 192.168x.x it doesnt Work!
Thanks for the Studerus Support
So this is a site to site setup if tunnel shows up and connected you like need to make a rule to allow the traffic like LAN to WAN with source/destination IP from what I remember because currently their is no zone for the tunnel on FLEX100H it uses the to zone of the VPN going out the WAN
Thanks, but there is a Zone for IPSEC in the Object Zone.
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 458 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
