FLEX100h VPn to ATP doesnt Work
SamuelJucker
SamuelJucker Posts: 3 image  Freshman Member
VPn Config with Wizard, VPn Tunnel OKAY, but no traffic. What ist the Problem?
  • SamuelJucker
    i have found the Problem. In the VPN Remote fails the Subnet. With 192.168.X.X/24 it Works. Only 192.168x.x it doesnt Work!
    Thanks for the Studerus Support
    edited November 2023
    So this is a site to site setup if tunnel shows up and connected you like need to make a rule to allow the traffic like LAN to WAN with source/destination IP from what I remember because currently their is no zone for the tunnel on FLEX100H it uses the to zone of the VPN going out the WAN
  • SamuelJucker
    Thanks, but there is a Zone for IPSEC in the Object Zone.
  • SamuelJucker
