[NEBULA] Spotify Connect blocked by Content Filtering
Hi Chris,
I have this problem with my USG Flex 200.
Please help me to be able to listen to music again! :)
Thanks,
Did you enable the option of Drop connection when there is an HTTPS connection with SSL v3(or previous version)?
if so, please disable it and try again.
Hi James,
it was enabled, and disabling that seems to have done the trick!
Many thanks! :)
- 588 USG FLEX H Series
- 477 News and Release
