[NEBULA] Spotify Connect blocked by Content Filtering
2»
  • TheEternalNocturnal
    TheEternalNocturnal Posts: 2 image  Freshman Member
    Hi Chris,
    I have this problem with my USG Flex 200.
    Please help me to be able to listen to music again! :)
    Thanks,
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    @TheEternalNocturnal
    Did you enable the option of Drop connection when there is an HTTPS connection with SSL v3(or previous version)?
    3106 Drop connection when there is an HTTPS connection with SSL v3(or previous version).png
    if so, please disable it and try again.
    Hi James,
    it was enabled, and disabling that seems to have done the trick!
    Many thanks! :)
Nebula Tips & Tricks
