MAC address information on NSG
It's an idea from @ComputeInTheCloud that there should be displayed the MAC addresses of all NSG interfaces somewhere on NCC.
Have you implemented this feature?
It could also be useuful for ATP and USG.
Hi @mARsIM,
You can check the MAC address information in site-wide > clients. This page displays the clients connected to AP, Switch, and Firewall/Security Gateway.
Zyxel Melen0 -
Hi Melen, ok but where i can see others interfaces MAC?
For example, one of our ATP has MAC XX:XX:XX:XX:XX:C2 shown in Client List page but if i check in the ports switch details where it's connected, i can see MAC XX:XX:XX:XX:XX:C4 , XX:XX:XX:XX:XX:C5, XX:XX:XX:XX:XX:C6 and there isn't MAC ending with "C2"
These MAC are not visible under clients list page as you suggested. It's visible only the mac "C2" in that list
It is important know all MAC for example to setup L2 isolation in SSID guest so it should be better display all interfaces mac address in the firewall page or somewhere in the firewall/interfaces page.
Thank you!
Hi @mARsIM,
Thanks for your feedback~
Actually, NSG can check the MAC address of each interface/port on the device detailed page. However, ATP and USG FLEX do not support it. May I know if you hope the Nebula displays each interface's MAC address of ATP/USG FLEX on the device detailed page?Zyxel Melen0 -
Sure Melen, why not?! ;) I think It can be useful for everyone
Hi @mARsIM
Thanks for your feedback. I have created the idea post for you. Here's the link of the idea post:
Zyxel Melen0 -
Great! Thank you Melen
- 221 Nebula Ideas
- 612 USG FLEX H Series
- 53 Wireless Ideas
- 300 Service & License
- 483 News and Release
