Vlan trunk
Hi @Jacekr2,
Good day.
All trunk port must be configured with tagged out to send tagged VLAN to the other devices.
To avoid misunderstanding, I would like to confirm that UT = Untagged out, right?
If yes, please modify your configuration as follows:1- Vlan1 1-35 UT, Vlan4 37-48 UT, Trunk 36 (port in Vlan1 Tagged out, Vlan4 Tagged out)2- Vlan1 1,3-36 UT, Vlan4 37-48 UT, Trunk 2 (port in Vlan1 Tagged out, Vlan4 Tagged out)
Note: VLAN1, port 2 must be tagged out.
Hope it helps!Zyxel_Jonas5
Hi @Jacekr2
Easy way to do it.
Switch 1 port A (vlan1) connected to Switch 2 port B (vlan1)
Switch 2 port C (vlan4) connected to Swtich 2 port D (vlan4)
But I am sure that you want to do it with an unique cable.
So you need 802.1q (Vlan tag) configuration.
Guide to configure vlan tag:
https://support.zyxel.eu/hc/en-us/articles/360001390814-How-to-configure-VLAN-on-a-Zyxel-Switch-Video-Tutorial-Series-VLAN-Configuration-
Best regards
Thank you for your response,
I just want network traffic to take place over 1 cable.
two GS1900-481- Vlan1 1-35 UT, Vlan4 37-48 UT, Trunk 36 (port in Vlan1 UT, Vlan4 UT)2- Vlan1 2-36 UT, Vlan4 37-48 UT, Trunk 2 (port in Vlan1 UT, Vlan4 UT)
connected 36 - 2
what is wrong0 -
Hi @Jacekr2,
Good day.
Hope it helps!Zyxel_Jonas5 -
- 588 USG FLEX H Series
- 477 News and Release
