Cannot Login to USB FLEX 50
bbtv
bbtv Posts: 2 image  Freshman Member
edited November 2023 in Nebula
I am having some difficulty in login to console. the user name field is disabled. On inspection I can see that the input field is 'readyonly'. It's having a default username as support. But I have been asked to use 'admin' and pwd '1234'. Any suggestions would be greatly appreciated.
  • Zyxel_Cooldia
    edited November 2023 Answer ✓
    Hi @bbtv ,
    The firewall is in Nebula mode, password is at Site-wide > Configure > Site settings > Local credentials. Please use local credentials to log in device local web gui.
  • smb_corp_user
    smb_corp_user Posts: 172 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Unfortunately, I don't know the exact cause or exact solution. I can only suggest that your unit contains a custom firmware and that you may have to install a default firmware to solve your problem.
  • Zyxel_Cooldia
    Hi @bbtv ,
  • bbtv
    Thanks . It solved the problem.
Nebula Tips & Tricks
