MAC address information on NSG
Zyxel_Freda
Zyxel_Freda Posts: 397 image  Zyxel Employee
25 Answers First Comment Friend Collector Third Anniversary
edited April 2021 in Nebula
It's an idea from @ComputeInTheCloud that there should be displayed the MAC addresses of all NSG interfaces somewhere on NCC.
  • mARsIM
    mARsIM Posts: 11 image  Freshman Member
    Have you implemented this feature?
    It could also be useuful for ATP and USG.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,021 image  Guru Member
    Hi @mARsIM,
    You can check the MAC address information in site-wide > clients. This page displays the clients connected to AP, Switch, and Firewall/Security Gateway.
    Zyxel Melen
  • mARsIM
    Hi Melen, ok but where i can see others interfaces MAC?
    For example, one of our ATP has MAC XX:XX:XX:XX:XX:C2 shown in Client List page but if i check in the ports switch details where it's connected, i can see MAC XX:XX:XX:XX:XX:C4 , XX:XX:XX:XX:XX:C5, XX:XX:XX:XX:XX:C6 and there isn't MAC ending with "C2"
    These MAC are not visible under clients list page as you suggested. It's visible only the mac "C2" in that list
    It is important know all MAC for example to setup L2 isolation in SSID guest so it should be better display all interfaces mac address in the firewall page or somewhere in the firewall/interfaces page.
    Thank you!
  • Zyxel_Melen
    Hi @mARsIM,
    Thanks for your feedback~
    Actually, NSG can check the MAC address of each interface/port on the device detailed page. However, ATP and USG FLEX do not support it. May I know if you hope the Nebula displays each interface's MAC address of ATP/USG FLEX on the device detailed page?
    Zyxel Melen
  • mARsIM
    Sure Melen, why not?! ;) I think It can be useful for everyone
  • Zyxel_Melen
    Hi @mARsIM
    Thanks for your feedback. I have created the idea post for you. Here's the link of the idea post:
    Zyxel Melen
  • mARsIM
    Great! Thank you Melen
Nebula Tips & Tricks
