VMG8825-T50 V5.50(ABOM.8.2)C0 : How to schedule wifi ?
[Deleted User]
[Deleted User] Posts: 4 image  Freshman Member
edited October 2023 in Smart Home Product
Capture d’écran du 2023-10-22 19-13-20.png Capture d’écran du 2023-10-22 19-15-01.png
I updated my firmware to the latest version (V5.50(ABOM.8.2)C0).
But since then, I cannot find the wifi scheduler entry (Berfore : Network/Wireless/Wifi Scheduler).
I did create a new rule (Security/Scheduler/Add a new rule).
But I cannot find the way to enforce it (Wifi on/off).
Any idea ?
  • Liba
    Liba Posts: 212 image  Master Member
    First Comment First Answer Third Anniversary
    It doesn't seem to support wifi on/off, maybe you can ask your ISP or retailer.
