GS1900-24 - Latest firmware: Importing p12 certificate fails with error 0x246
Hello, I'm trying to import a p12/pfx file generated using the following command:
openssl pkcs12 -export -out switch.pfx -in switch.crt -inkey switch.key
on a GS1900-24 switch (Rev. A1, Firmware V2.80(AAHL.0) | 10/16/2023).
However, it always fails with the following alert (see image below too):
Upload certificate failed. Unspecified error(0x246)
I tried several things now but can't get it to work.
Any ideas?
Hi @zyste,
Thanks for your kind correction. Please allow me to rephrase my previous explanation. After checking I found that GS1900 only supports the RSA algorithm but not the ECDSA algorithm. Could you generate an RSA algorithm certificate file and import it to GS1900?
Zyxel Melen1
Hi @zyste,
Could you share the certificate with me? I will try to reproduce it on my side. Please check the private message I sent to you and provide the certificate and its password there.
Zyxel Melen1 -
Hello @Zyxel_Melen, I sent you the p12 file via PM.
Hi zyste, thanks for the file! I will test it next week and keep you posted.
Zyxel Melen0 -
Hi @zyste,
After checking, I found that GS1900 only supports .pfx file but not .p12 file. Could you generate a .pfx file and import it to GS1900?
Zyxel Melen0 -
Hi @Zyxel_Melen,
I think there's a technical misunderstanding on your side - pfx and p12 is essentially the same thing, just the extension is different. So, you'd just have to rename the file to e.g. certificate.pfx
As far as I remember I tried that too but got the same error - as reference, see the extensions at the Wikipedia page.
Hi @zyste,
Zyxel Melen1 -
Hello @Zyxel_Melen,
thank you for the hint - I used RSA and now it indeed worked!
As a suggestion, a better error message in a future firmware release would be really helpful - or at least an explanation of what error 0x246 means somewhere on the Zyxel knowledge base or similar.Discussion closed - thanks again for your help and have a nice day!
Hi @zyste,
Thanks for your input. We have already discussed this part and recorded it in the enhancement checklist. Stay tuned for our future firmware release.
Zyxel Melen0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
