[Campaign] Zyxel Network Detective - Case #3 is OPEN! (Answer Revealed)
Solve a Firewall Enigma
Greetings, fellow tech enthusiasts!
Following the resounding success of our Case #2: Crack the Case for WiFi Network challenge, we are thrilled to introduce our final quest, Case #3: Crack the Case for Firewall. If you relished resolving network errors in our previous challenges, prepare for an exhilarating journey deep into the security firewalls and win fantastic prizes now.
You’re not on your own in this mission! Become part of conversations alongside other tech enthusiasts, share your observations, and exchange your findings HERE!
In Pursuit of Glory, Zyxel Detective!
Hello detectives!
Do you know how to configure site-to-site VPN in Nebula between two devices under one organization?
Steps:
- Select
WAN interfaceto establish the VPN tunnel - Select
LAN Subnetthat can be accessed through the VPN tunnel
- Select “
Site-to-Site” in Nebula VPN topology - Repeat step1 to step3 on the other firewall
What’s even better, settings in step 1-3 can be configured in a single page!
Once the VPN connection is established, you can monitor the VPN connection state under each site.
Keep up the investigation,
Watson🕵️
When you have eliminated the impossible, whatever remains, however improbable, must be the truth.
0 - Select
I'm certain you've pieced all the puzzles together, Zyxel Detective!
Check out the revealed answer here!
We'll be reuniting with you very soon and thank you for joining the hunt!
Watson🕵️
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
