wap 3205 v3 with microtik
hiya friends i had a wifi wifi with mikrotik. when i input to wap3205 any port mikrotiks has ethernet link down always. when i plug to my directly computer there is no ethernet link down. i firmware uptade it is still same.. any idea what can be problem..
Hello @recepkarapinar
Welcome to the forum.
Are you able to say what firmware version you have in your WAP3205 v3 please?
I found a user guide for WAP3205 v3 at https://download.zyxel.com/WAP3205_v3/user_guide/WAP3205%20v3__v1_ed4.pdf
Is there anything in the logs of your WAP3205 v3 to show that Ethernet link is down?
Kind regards,
Tony
hiya friend thanks for replay
i am using
System Name :WAP3205 v3
Firmware Version :
V2.00(ABDM.4)C0
on logs
970-01-01 00:00:07
3
system
LAN port link up
1970-01-01 00:00:09
4
system
LAN port link down
1970-01-01 00:00:18
5
system
LAN port link up
like this always
You are welcome @recepkarapinar .
There is a V2.00(ABDM.5)C0 firmware release from March 2022 available in the Downloads area linked from https://www.zyxel.com/uk/en-gb/products/wifi-extender/wireless-n300-access-point-wap3205-v3
The release notes do not mention a specific item for this, but it might be helpful to you.
Do you have any logs from your device (router?) on the other end of the LAN port link?
- there might be an issue at that end of the LAN port link…
Kind regards Tony
hiya again lan port end side is ok. when i plug and to computer or any different acsess point i cant see link down on mikrotik when i plug wap 3205 also i had nbg 418 n v2 it has same problem
If you have 2 different access points on the end of the same cable and router with the same problem, then it suggests to me that there is an issue that is common to both of them.
It is unlikely to be a software issue common to both, but software reuse does happen.
Have you confirmed that the LAN cable is ok?
Kind regards,
Tony
hiya yes i did
when i plug end of lan from mikrotik in coming if i put that different acsess point like tplink there is no ether link down.
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
