It's been a week but still no proper answer! How irresponsible is this?
Ömer
Ömer Posts: 13 image  Freshman Member
edited July 2024 in Consumer Idea
I think these features should come to VMG3625-T50B and some problems should be solved 😀
I installed abpm8 c0 version but later went back to 7.3 c0 version.
In my opinion, the features that need to be introduced and fixed are;
Manual snr margin adjustment setting should come,(very important)😊
Qos, works in version 7.3 c0, does not work in version 8 c0, pls to fix this.
(i used packet lenght )
Turning the front LEDs on and off,
Providing more control options via the Mpro mesh application (there is a menu in the form of parental control in version 8 c0)
The hidden network still does not turn off, the hidden network is still active in version 8 c0, this should be fixed (even if mpro mesh and wps is turned off)
IPv6 is defined, but some versions can use it, some versions cannot use …
3 votes
Active · Last Updated
