DX3301-T0
Waldy
Waldy Posts: 1 image  Freshman Member
edited December 2023 in Home Router
My voip phjone stops ringing after 10 minutes. the line rings and I can make outgoing calls. I have been advised to turn off SIP ALG but cannot find it in the above router
Any Clues
  • Liba
    Liba Posts: 211 image  Master Member
    First Comment First Answer Third Anniversary
    I think you can find this setting on the NAT page. If it cannot be solved, you may need to check the voip settings on the phone and DX3301-T0.
