Does NBG7510 support WPA3 SAE fully?
tonygibbs16
in Home Router
Does NBG7510 fully support WPA3 SAE fully?
I have an NBG7510 running V1.00(ABZY.3)C0 and if I try to connect a Samsung device running Android 13 and it does not always connect on 5GHz and it says "Connected without Internet" when I know that the WAN is working.
- when I have set it to WP3 SAE/WPA2 Personal
Thoughts?
Kind regards,
Tony
I think that I might have had finger trouble and had set it on the wrong WiFi band, because my Samsung Galaxy is now connected on 5GHz, but I don't know if it is using WPA3 SAE.
My Windows laptop is also connected, but seems to be only using WPA2 Personal.
Kind regards,
Tony
- 591 USG FLEX H Series
- 479 News and Release
