UPS Automatically Shutdown
Franc
Franc Posts: 27  Freshman Member
edited April 2021 in Security
My last USG100 was killed by a power outage. (POWER Led Always RED)
Is there a way to automatically shutdown when a power outage occurs (UPS start to work) as happens, for example, with Synology NAS?
  • Franc
    Hi Emily,
    thank you, I'll try and I'll let you know.
    For the console connection do I need of a standard Serial DB9 cable?
    In the USG 100 box there was a blue DB9-RJ45 cable. What is it for?
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,435  Zyxel Employee
    Hi @Franc,
    In the box of USG 100, there should be one RS-232 console Y-cable.
    You can also find one HL-340 RS232 and connect HL-340 RS232 directly between the USG 100 and PC.
  • Franc
    Dear Emily,
    I made the connection, I switched on the USG 100,  but nothing apear...black screen, any suggestion?
    Thankyou
  • Zyxel_Emily
    Hi @Franc,
    Did you install TeraTerm and select the serial port?
