It's been a week but still no proper answer! How irresponsible is this?
I think these features should come to VMG3625-T50B and some problems should be solved 😀
I installed abpm8 c0 version but later went back to 7.3 c0 version.
In my opinion, the features that need to be introduced and fixed are;
Manual snr margin adjustment setting should come,(very important)😊
Qos, works in version 7.3 c0, does not work in version 8 c0, pls to fix this.
(i used packet lenght )
Turning the front LEDs on and off,
Providing more control options via the Mpro mesh application (there is a menu in the form of parental control in version 8 c0)
The hidden network still does not turn off, the hidden network is still active in version 8 c0, this should be fixed (even if mpro mesh and wps is turned off)
IPv6 is defined, but some versions can use it, some versions cannot use …
Isn't there anyone ?
topic is active
I have another problem with VMG8623-T50B that uses the same firmware 8.0C0 and 8.1C0.
5Ghz wifi is working but "this network doesnt have internet access"
-1 -
@boneorchid Update the software version to 7.3 c0.
konu hâlâ aktif
Hello @Ömer
I think that this section of the forum is for ideas from consumers like us that should be considered to be fixed in future firmware releases and products, rather than for immediate quick workarounds.
Merry Christmas and Happy New Year 2024 to you.
Kind regards Tony
Yes, that's what I'm talking about too.There is no urgency in the software. I can only provide feedback.We, the users, do not want to have problems with every update. Qos was working, now it's not working. Etc.Please pay attention to the software for this device.Thank you. Merry Christmas to you too. @tonygibbs16
Hello.You can download the software from the address I provided. @aka_khaliid
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
