GS1200 DHCP Client and Mikrotik Issue
Hi.
We have Mikrotik devices and Zyxel switches on access level (GS1200-8)
Switches receives address by DHCP from Mikrotik main router.
Sometimes some switches (not all) can’t renew address from DHCP and have status waiting
In mikrotik log we have next messages:
"lease waiting, addressed to me, fix-selecting-init-reboot, init-reboot, authorative or unicast, acquire"
"lease acquire failed: got wrong ip"
What means this record in log? And how fix it, that GS1200 work properly?
Thank you.
P. S. This happened on latest 2-3 firmwares. On older firmwares all work ok.
Update:
This issue has been fixed. We will add this fix to the future firmware release.
Zyxel Melen0
Hi @andyvolk,
Based on the log you provided, I am not sure if these logs are related to the GS1200 DHCP renewal problem. Could you share the whole log file (during DHCP renewal) for me to check? Also, could you confirm with Mikrotik support to check this log's meaning? What is your Mikrotik router OS/firmware version? Which GS1200 firmware version worked ok?
Zyxel Melen0 -
I write to Microtik support too, but think problem is from Zyxel side. Other devices work ok, and some zyxel switch too.
After power off/on switch receive address, but after some times (3 days - 1 week) issue appears again.Fimware was before V2.00(ABME.1)C0 or older, and works ok.
Here's full screen from mikrotik log
Hi @andyvolk,
Thanks for the logs. These logs look like your Mikrotik router rejected the GS1200's DHCP request. The Nak packets are usually sent by the DHCP server. In addition, I did a local test in my office with Mikrotik router (RouterOS v6.45.1) and GS1200(V2.00 Patch 3). But there's no problem in my test. The DHCP lease time in my lab was 10 minutes. This is used to speed up reproduction.
The below screenshots are the logs on my Mikrotik router.Zyxel Melen0 -
This problem appears after some time, and not immediately. If you can please try to build a setup with 3-4 GS1200 with RouteOS 7 and leave it for a week for example.
When I power off and then power on shitch all works fine for some times. But then lease not receive.
Hi @andyvolk,
Thanks for your feedback. I'm running the reproduction with RouterOS v7.13. In the meantime, could you share your DHCP server configuration with me? I just want to make sure my configuration is the same as yours.
Zyxel Melen0 -
Here is my DHCP on Mikrotik
Also i forget to say, that also on zyxels (and whole network we use VLANs). Settings GS1200 likes this (1 port is uplink to top level switch):
Maybe it is important to reproduce issue.
Currenly stats in network for zyxels:
Total 29 items, 10 of them not receive DHCP address,
9 from 10 are plugged via Mikrotik CSS326, and one via CRS326.
Uptime: 8 days1 -
Hi @andyvolk,
Thanks for the update. I'm running the test for a few days. In the meantime, could you share your topology with me? I would like to check if the GS1200 is directly connected to the Mikrotik router.
Zyxel Melen0 -
I do not have topology of this network (it so large), but have topology from similiar network. That topology is smaller, but have same issues with DHCP client.
Blue lines - fiber link
greed lines - tagged vlans ethernet link
black lines - simple linkLast time DHCP issue was at Zyxels marked 1,2,3,4
Would you be able to Wireshark DHCP on the working firmware and non working firmware? As maybe renew request has changed that the Microtik will not renew
set lease to 3mins to speed up the capture.
Hi @andyvolk,
Thanks for the topology. To speed up the investigation, could you help capture the DHCP packets on the Mikrotik router when the issue occurs? Please find the capture steps below:
- Set the filter conditions and start capturing.
- Click the packets button and you will find the captured packets. Please share the results with me. Thanks in advance.
Zyxel Melen0
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
