Please help recommend a suitable firewall.
Hi @Weerapong ,
Greeting Forum, I assum you will have UTM feature and the each End Client have 3MB/s traffic. (General Condition) .
Looking for the UTM throughput in Datasheet, Here are the mount Firewall can afford.
ATP800: (1900/8/3) = 80
FLEX700: (1450/8/3) = 60
USG310: (550/8/3) = 23
Note:
-Test condition:
Anti-malware (with Express mode) and IPS throughput measured using the industry standard HTTP performance test (1,460-byte HTTP packets). Testing done with multiple flows.
-These data can be influenced by various factors, so they are provided for reference only. Additionally, we do not recommend using the USG310 as it has been EOL.
Thank you
I don't understand the numbers. What are they? Can you explain? For example: FLEX700: (1450/8/3) = 60
what is 1450 8 3
Hi @Weerapong ,
Please kindly find those value in Datasheet.
For example: ATP800 with 1900 UTM Throughput.
so 1900bit/s divide 8 = 237.5 Btyte/s
237.5 divide 3 (each client traffic) = 80 .
Find the ATP800, FLEX700 datasheet.
https://download.zyxel.com/ATP800/datasheet/ATP800_15.pdf
https://download.zyxel.com/USG_FLEX_700/datasheet/USG%20FLEX%20700_10.pdf
Thank you
If I have 185 computers, which model do you recommend? Currently I use USG310.
I would say the Flex 700
or maybe this will help
https://support.zyxel.eu/hc/en-us/articles/360017538120-What-Firewall-should-I-use-
Really liked the VPN-series to bad they EOL them so soon
Hi @Weerapong ,
No matter if it's ATP800 or Flex700, both have higher performance than USG310.
ATP is default bundled with a one-year Gold Security Pack license. If you need all UTM features, you can choose ATP series.
If you are not quite sure if all UTM features are necessary in your network, you can chooses USG FLEX with bundled UTM Security Pack. After the 1-year UTM Security licenses are expired, you can then choose Gold Security Pack or UTM Security Pack based on your needs.
Thank you
@weerapong license packs are "optional" and provide more services (under yearly fee) that might or might not interest or be necessary to your use.
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 319 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
