wap3205 time sync
muengger
Hi i have 3 wap3205 in my House they are working as access points correclty.
But it's not possible to use ntp server for the system time. when i set in the webinterface the time and a power fail occours the system time is reseted.
So it's the time programming for wlan is not usable after a powerfail. configurating a timeserver will be very good. i have the V2.00(ABDM.5)C0 installed…
If you probably make i new firmware it will be good to add timeserver settings….
Other wise there is no sense for wlan time programming…
Best Regards
Thomas
AFAIK, wap3205v3 do not have latest firmware…
Maybe you can consider other products as an access point in your house.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
