No Rover app avialable in Google Store
Try to download the app, but it is not avialable in Store. Somehow it could be found, but it said that is not compatible with my android version. Very strange, since it Android 13. Also, it happens the same with a Samsung Galaxy S22 Plus. By the way, my region is Spain.
You are using S22, I think your Android version may be in 13 or 14.
The reason might be that the app is not compatible with the latest version of Android.
On my Android 13, many apps which do not update versions have recently shown they do not support the latest version.0 -
I have the Rover app working on my Android phone running Android 11, but have not tried it on my work Samsung that is running Android 13.
I have just noticed on the Google Play Store that the Rover app has not been updated since May 2022, so I will suggest to Zyxel that they update it.
Kind regards Tony
- 441 Beta Program
- 293 Service & License
