Please help recommend a suitable firewall.
Weerapong
Weerapong Posts: 8  Freshman Member
I would like to know about each of the following Firewall models: How many computers is suitable?
1. USG310
2. USG Flex700
3. ATP800
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 958  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @Weerapong ,
    Greeting Forum, I assum you will have UTM feature and the each End Client have 3MB/s traffic. (General Condition) .
    Looking for the UTM throughput in Datasheet, Here are the mount Firewall can afford.
    ATP800: (1900/8/3) = 80
    FLEX700: (1450/8/3) = 60
    USG310: (550/8/3) = 23
    Note:
    -Test condition:
    Anti-malware (with Express mode) and IPS throughput measured using the industry standard HTTP performance test (1,460-byte HTTP packets). Testing done with multiple flows.
    -These data can be influenced by various factors, so they are provided for reference only. Additionally, we do not recommend using the USG310 as it has been EOL.
    Thank you
  • Weerapong
    I don't understand the numbers. What are they? Can you explain? For example: FLEX700: (1450/8/3) = 60
    what is 1450 8 3
  • Zyxel_Kevin
    Hi @Weerapong ,
    Please kindly find those value in Datasheet.
    For example: ATP800 with 1900 UTM Throughput.
    so 1900bit/s divide 8 = 237.5 Btyte/s
    237.5 divide 3 (each client traffic) = 80 .
    Find the ATP800, FLEX700 datasheet.
    https://download.zyxel.com/ATP800/datasheet/ATP800_15.pdf
    https://download.zyxel.com/USG_FLEX_700/datasheet/USG%20FLEX%20700_10.pdf
    Thank you
  • Weerapong
    If I have 185 computers, which model do you recommend? Currently I use USG310.
    PeterUK Posts: 3,892  Guru Member
    I would say the Flex 700
    or maybe this will help
    https://support.zyxel.eu/hc/en-us/articles/360017538120-What-Firewall-should-I-use-
    Really liked the VPN-series to bad they EOL them so soon
  • Zyxel_Kevin
    Hi @Weerapong ,
    No matter if it's ATP800 or Flex700, both have higher performance than USG310.
    ATP is default bundled with a one-year Gold Security Pack license. If you need all UTM features, you can choose ATP series.
    If you are not quite sure if all UTM features are necessary in your network, you can chooses USG FLEX with bundled UTM Security Pack. After the 1-year UTM Security licenses are expired, you can then choose Gold Security Pack or UTM Security Pack based on your needs.
    Thank you
  • mMontana
    mMontana Posts: 1,432  Guru Member
    @weerapong license packs are "optional" and provide more services (under yearly fee) that might or might not interest or be necessary to your use.
