Mounting Brackets for GS1920
Heya @Homer_SI had the same issue for months with one of our switch models . We misplaced one pair of mounting brackets a while back and grabbed a pair from our spare switch. As we upgraded and replaced switches, cycling out the spare, we were juggling the brackets.
My contractor that supplies my Zyxel switches had been trying for months to order a pair of these brackets to have as a replacement for the lost brackets, but Zyxel had no way to get these ordered.
In the end, i had someone custom make the brackets out of aluminum in our machine tool department, which I am lucky enough to have. You might be able to find a company in your local area that can fabricate one, or even 3D print one. My Machine Tech said that it was an incredibly easy fabrication.
This would be a good option.
https://www.amazon.com/dp/B0D2R32N4N?ref=fed_asin_title
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 269 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
