XGS1930-28 LACP vlan configuration
Hi @hades,
Please set both the LACP ports as the VLAN's members. For example, if I group ports 7 and 8 as LACP members.
I have to fix ports 7 and 8 as VLAN 10's members.
In addition, please do not set only one port as the VLAN's member. Or the traffic might not be forwarded correctly.
Hope it helps.
Zyxel Melen0
Hi @hades,
Hope it helps.
Zyxel Melen0 -
Thanks for your reply. This works indeed. However, this is a bad implementation, since this allows for inconsistent configuration :-( A network device should be designed in a way that it should prevent this kind of inconsistency, to keep the possibility of outages in networks to a minimum.
Hi @hades,
Thanks for your feedback. I have help you create an idea post and we will monitor for it.
Zyxel Melen0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
