XGS1930-28 LACP vlan configuration
hades
hades Posts: 2
How to configure vlans on a LACP port on the XGS1930-28 ? I can't choose a LACP port in the vlan configuration, only the physical ports (1-28) can be selected.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,602 image  Zyxel Employee
    Hi @hades,
    Please set both the LACP ports as the VLAN's members. For example, if I group ports 7 and 8 as LACP members.
    I have to fix ports 7 and 8 as VLAN 10's members.
    In addition, please do not set only one port as the VLAN's member. Or the traffic might not be forwarded correctly.
    Hope it helps.
    Zyxel Melen
  • Zyxel_Melen
    Hi @hades,
    Hope it helps.
    Zyxel Melen
  • hades
    hades Posts: 2
    Thanks for your reply. This works indeed. However, this is a bad implementation, since this allows for inconsistent configuration :-( A network device should be designed in a way that it should prevent this kind of inconsistency, to keep the possibility of outages in networks to a minimum.
  • Zyxel_Melen
    Hi @hades,
    Thanks for your feedback. I have help you create an idea post and we will monitor for it.
    Zyxel Melen
