wan failover at flex200HP
wan failover currently can't be done by routeing and should be possible to do ARP failover in trunking.
Make a new User-Defined Trunk add in WAN set one the active the other to Passive
You then may need to make a routing rule for next hop trunk you have made
their is also interface pinging check that you can enable
Edit: testing here shows it working as said above you you need interface pinging check on active WAN when it fails it changes to the Passive WAN then when active WAN is up you switch back for new connections
thnx i am not a it pro so i try to set this. (i dont understand it yet but try to work it out)
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
