Nr5103 Upgrade the firmware of fwa510.
shak
shak Posts: 10
Can Nr5103 upgrade the firmware of fwa510?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @shak ,
    Unfortunately, the firmware for the FWA510 is not compatible with the NR5103. Each Zyxel device has its unique firmware tailored to its hardware and software configurations. It's crucial to use the firmware specifically designed for each model to ensure compatibility and functionality.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @shak ,
    Zyxel_Judy
    Untitled Image
  • shak
    shak Posts: 10
    nr5103Nr5103 hasn't been updated yet, has it been forgotten?V4.19(ABYC.3)C0
  • shak
    shak Posts: 10
    as soon as possibleUpdate the firmware as soon as possible, there is no security update.
  • Zyxel_Judy
    Hi @shak ,
    Regarding the NR5103 issue, I recommend reaching out to your local support team for assistance with this request.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
