[NEBULA] Is VLAN supported on Hybrid Switch under free-cloud license?
5
Hello @"林追追"
VLAN settings are available on NCC even without any Nebula licenses.
But please be aware that the VLAN settings of the GS1920-24v2's Web GUI and Nebula CC uses the same core concepts, but different UI and settings.
If you need to learn how to configure the Nebula Switch with a public/private SSID, kindly refer to the link below:
https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=016557&lang=EN
Hope this helps!
Regards,
Barney Gregorio0 -
Nebula_Barney said:Hello @"林追追"
Hope this helps!
Regards,
Barney Gregorio0 -
5
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
