gs1915 ip setup
klaeuser
klaeuser Posts: 6 image  Freshman Member
I have a GS1915-24 and a 1915-8.
Both work very good, but both show this message in the system log (over and over):
ER system: Gets the time and date from a time server failed
IP configuration looks good to my mind, but the strange thing is, I cannot ping/traceroute any IP address. The switches have static IP addresses and the only addresses, that give me a response are just these static addresses.
Example:
address: 192.168.88.25
subnet mask: 255.255.255.0
default gateway: 192.168.88.1
No other address responds - not even the gateway.
I also configured management IP addresses, but they also cannot be pinged … not even the adresses of the switch itself.
I suppose there's something wrong with that configuration and that this is the root cause why no ntp servers can be reached - but I have no idea what the problem could be
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    edited January 2024 Answer ✓
    Hi @klaeuser,
    Did you use the switch diagnostic tool to ping the default gateway of your switch, which is 192.168.88.1, but failed? If yes, please:
    1. Check the connection between your switch and the default gateway.
    2. Check if there is an IP conflict.
    Or does your switch have a default gateway?
    In addition, since the NTP server address usually uses a domain name, you must set a domain name server to resolve the domain name.
    Zyxel Melen
  • Zyxel_Melen
    Hi @klaeuser,
    Zyxel Melen
