Lan to L2TP Ping
Nakyll
Nakyll Posts: 10  Freshman Member
Clients on local Lan with /16 subnet (255.255.0.0) are not routed to the gateway (zyxell usg) and they don't see the l2tp client
If i swap the local client to /24 (255.255.255.0) the local clien si routed and ping is working
any suggestion?
    PeterUK Posts: 3,863  Guru Member
    edited January 2024
    Because you over lap a subnet that the l2tp clients are on then what the Lan uses.
    if you have 192.168.0.0/16 as LAN and l2tp clients as 192.168.50.0/24 the LAN over laps this and clients will ARP in that LAN subnet not knowing going to gateway to look for l2tp client on 192.168.50.0/24
  • Nakyll
    ok got it thanks, i 'll creat a persistent route on the target ip.
