WLAN with NWA55AXE
Is it possible to operate the NWA55AXE as a WLAN amplifier without a LAN connection? I don't have a LAN connection in the garden house.
greeting
Marcus
Best Answers
Yes, all Zyxel access points, including the NWA55AXE, can function as a Repeater AP (essentially a WLAN amplifier without a direct LAN connection) as long as there is another Zyxel AP serving as the Root AP.
To help you set up a mesh (wireless connection) between two Zyxel APs, we have FAQs tailored for different modes of operation:
Be a Community MVP: Win a VIP Deal Dash on Your Next Zyxel Purchase!
Hi @Niro96 ,
We would like to explain the workings of the smart mesh and wireless bridge mechanism.
As of now, if a repeater AP with wireless bridge enabled connects to a root AP that does not support this function (such as the NWA50AX PRO in your scenario), the repeater AP will attempt to utilize the wireless bridge feature. However, due to the root AP's lack of support, the repeater AP will disconnect from it after 30 minutes to search for other root APs that support wireless bridge.
If the repeater AP fails to find any suitable root APs in the current network environment, it will eventually reconnect to the original root AP. This process results in the issue you've observed.
To avoid this, please disable the wireless bridge function if it is not required. It's crucial to note that for the wireless bridge feature to work properly, both the root AP and the repeater AP must support the wireless bridge functionality.
I think the WX3100-T0 is in this situation better.
Thanks for the reply. I had already tried these options yesterday without instructions.
Maybe I made a mistake. A question about the instructions for Nebula cloud mode.
The step is to deactivate the downlink mesh on the AP. Where do you find this setting?
And does LAN mean the AP or the repeater?greeting Marcus
Hi @Niro96 ,
Device > Access points > AP information page > Status > Smart mesh.
If you wish to prevent any Repeater AP from connecting to this AP, please disable the Downlink feature.
I'm not entirely clear on your question. Just as a reminder, Nebula's Smart Mesh allows you to connect two or more APs wirelessly, without the need for Ethernet cables.
Many thanks for the answer. Based on the screenshots I can understand where I have to set it.
I'll adjust the setting tonight. And I'll get back to you about this later.
The question "And does LAN mean the AP or the repeater?" was wrong. 😉0 -
Many thanks for the help. It works.
greeting
Marcus0 -
With the settings I have made, I have regular connection failures.
Could it be due to the distance between the root AP and the NWA55AXE?0 -
Even after I reduced the distance, the NWA55AXE stopped working regularly.
greetings Marcus
I have now deactivated the wireless bridge mode. Now it runs without any problems.
greeting
Marcus0 -
Hi @Niro96 ,
- 396 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 86 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 915 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 419 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
