[NEBULA]where i found the firmware for manual update of switch NSW Total Series? Thnak You very Much
2»
  • Zyxel_Jason
    Zyxel_Jason Posts: 425 image  Master Member
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @Pook ,
    Please check the followings first for your NSW100-28P:
    1. Your NSW100 is online on NCC.
    2. Your network environment can reach the domain firmware.nebula.zyxel.com which is our firmware server.
    =>You may ping firmware.nebula.zyxel.com from the Switch.
    3. You gateway or ISP doesn't block HTTPS(TCP 443)
    => Nebula device uses HTTPS to download firmware.
    If there is still having problem after checking above, please share your organization/site name and enable Zyxel Support at Help > Support request page, so we can access your organization to check.
    Thanks.
    Jason
  • krp
    krp Posts: 5
    I'm having the same issue whit NSW100-28P. IT shows in ncc but after about 5min ncc says it's offline, cannot update.
    And nsw 100-28p locator indicator is black, not blue
    Can you please advise what i can do?
  • krp
    krp Posts: 5
    I got to work, all ok
  • Zyxel_Jason
    Hi @krp,
    The symptom you mentioned is "Switch can be online on NCC but gets offline after 5 minutes".
    To identify the problem, please enable Zyxel Support at Help > Support request page of your organization, and share your organization/site/Switch name so that we can access your site to check.
    Thanks.
    Jason
  • HTU1973
    HTU1973 Posts: 4 image  Freshman Member
    GUYS, is there a solution?
    herer another victim stuck in V1.0
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,953 image  Guru Member
    edited January 2024
    Hi @HTU1973,
    Please upgrade your NSW series switch to the latest firmware. You can find the latest firmware for the NSW series switch on the End-of-Life webpage.
    You may also use ZON Utility to upgrade firmware.
    Hope it helps.
    Zyxel Melen
Nebula Tips & Tricks
