Info problem with sending logs to zyxel vpn100 email
integratedsolutions
integratedsolutions Posts: 16 image  Freshman Member
Good morning, I have a Zyxel VPN 100 firewall product and since this morning I have no longer received the email containing the various logs. How can I solve it? The configurations are all correct and no firmware update has been done. I await feedback.
Thank you,
Greetings
    PeterUK Posts: 4,254 image  Guru Member
    Maybe the Email server has likely changed? and is now blocking your logs?
    Or do you have your own Email server?
  • integratedsolutions
    My server is always the same, that is @libero.it. Suddenly he's not sending them. I did a smpt sending test and it regularly sends manually, but not automatically.
    I re-entered the smpt configuration including account and password and now I received a log. I'll wait until after the weekend to see the result but if it continues like this it will work. Will update. Thank you!
