Android 12 and ikev2
Hi @Peppino,
Thanks for feedback. We can refer to this FAQ to set up Strongswan in Android phone.
https://community.zyxel.com/en/discussion/12522/remote-access-vpn-wizard-for-secuextender-ipsec-and-non-secuextender-ipsec-vpn-clients#latest
Thanks Cooldia, I did not notice there is a whitepaper on this. :-)0
I'm trying to use the wizard to connect an android phone (samsung!) to an ATP with latest firmware, the firewall is under a router, I modified phase 1: in my address instead of "interface" i selected "domain name/IPv4" and entered my public (static) ip.
this is what i get on the firewall:
this is what i get from strongswan:
any help?
Is that same ip included in the certificate too?
update: i tried the same configuration on another firewall with the same firmware, the only difference is that the 2nd fw is not under NAT. In this case it works (same phone).
Well client VPN needs a fw exposed to a public IP. Hidden behind a NAT will obviously not work. The only exception is when this FW will act as a client to another one that has public IP, then they can build a tunnel between themselves.
actually the firewall it's not hidden: the ISP router is configured so that the Firewall ip (router lan / firewall wan) is in DMZ so that (theorically) all the traffic to the ISP router is redirected to the firewall.
I suppose that in this scenario one's able to connect via VPN, am I wrong?
If the certificate says a IP then the fw needs to have that IP and be WAN
for IPsec identifier on phone need to be:
ikev2
for IPSec pershared key
With strongswan I was able to setup on Zywall 110 a IKEv2 certificate VPN with a DNS by no-ip
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 91 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 918 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 920 Nebula FAQ
- 422 Security FAQ
- 237 Switch FAQ
- 208 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
