RADIUS: Rejecting User
We have a zywall 1100 and I am trying to configure it for client VPN access. The log is showing RADIUS: rejecting the user "username" however we don't have a RADUIS server configure. The authentication method is set to local and the username is configured locally on the firewall.
I can't understand why there is a radius error failing the authentication.
Am I missing something obvious or is this a n erroneous log entry?
I do not know for certain, but sometimes it can help to enable the setting, save settings, then disable the setting again (and save again). Only happened to me on smaller devices, though.
Turned out it was an erroneous error machine. The firewall was using local authentication, and there was a password mismatch
Thank you for the feedback. Happy to hear that you managed to solve the problem.
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
