GS1350- CLV not working
I have a new to me GS1350-6HP. Its running the latet 4.70 firmware as far as I can tell. Finding it very difficult to get the vlans doing what I want and am at the CLI trying to enable CLV mode (I am very familiar with cisco switches).
The CLI guide for the 1350 says I should be able to enable, config, clv to enter clv mode. I get an invalid command? What am I missing?
GS1350# enable
Password:
GS1350# config
GS1350(config)# clv
%Invalid command "clv"
GS1350(config)#
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,077 image  Zyxel Employee
    Hi @dazey77,
    Thanks for asking. It is because GS1350 does not support CLV mode. Please reference its datasheet. We apologize for the misleading since the CLI guide is a generic document. We will enhance this part for more clarity.
    Zyxel Melen
  • dazey77
    OK, well it would be good if the GS1350 CLI guide was renamed as a generic document. Its named as for the GS1350 (GS1350-26HP_V4.70_Ed2.pdf)
    and I followed the GS1350 link
    https://www.zyxel.com/global/en/support/download?model=gs1350-26hp
    Perhaps you could help me translate. In cisco world what I am trying to do is
    define a MAC group
    Cisco(config)#vlan database
    Cisco(config-vlan)#map mac 00:1d:c1:00:00:00 24 macs-group 1
    which I believe translates to
    vendor-id-based-vlan name "" source-mac 00:1d:c1:00:00:00 mask ff:ff:ff:00:00:00 vlan 400 priority 3
    I am not sure what I need to do for the VLANs and port settings.
    In cisco, I would define the Vlans and the port settings I am trying (unsuccessfully so far) to replicate are
    Cisco(config-if-range)#int range ge5-6
    Cisco(config-if-range)#switchport mode general
    Cisco(config-if-range)#switchport general allowed vlan add 100,400 untagged
    Cisco(config-if-range)#switchport general map macs-group 1 vlan 400
    Cisco(config-if-range)#switchport general pvid 100
  • Zyxel_Melen
    Hi @dazey77,
    Please reference the new post you created. I leave the configuration in that post.
    Zyxel Melen
