WRE2206
is it possible to connect this reapter via ethernet cable to router and then by wifi to PC?
Ive got very weak signal from Zyxel router, bought this reapter to connect via ethernet from wall and spread wifi signal, but it seems it does not support such connections. Ive tried to reapter by wifi signal froum router (2 LED are lighted on reapeter), but internet speed is joke.
Hello @misterwhite
Looking at the user guide at https://fccid.io/I88WRE2206/User-Manual/User-Manual-pdf-2621979.pdf the answer to your question is no.
- the WRE2206 is a wireless only extender.
You could use a Zyxel NBG7510 as an additional router to create another WiFi network and subnet for you, or use the NBG7510 in Access Point mode to give you the wired extension of WiFi, see https://download.zyxel.com/NBG7510/datasheet/NBG7510_3.pdf for details.
- I use my NBG7510 as an additional router connected to my ISP's router in my home office to provided a wired connection to the ISP router and WiFi for my devices.
Kind regards,
Tony
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
