AX7501-B0 Alternative WAN port ETH
ALiKyr87
ALiKyr87 Posts: 1 image  Freshman Member
Hi!
Can you choose another WAN port instead of the SFP 10GB port.
I have looked at the manual and also looked around in the WebGui, but just got more confused. I can't seem to choose the correct wan interface. See example below.
Thanks in advance
  • Liba
    Liba Posts: 214 image  Master Member
    First Comment First Answer Third Anniversary
    I think this WAN naming equals the 10G port.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @ALiKyr87
    Welcome to the forum.
    Looking at the user guide available at https://spdl.zyxel.com/AX7501-B0/user_guide/AX7501-B0_V5.15-V5.17%20Ed%202.pdf it seems like the AX7501 only has 2 Broadband WAN options: PON and Wireless WAN Cellular.
    The user guide reads that you can use Cellular as a WAN backup or if the fibre connection is disconnected then cellular would be primary. But that the AX7501 automatically uses wired connection when available, see below extract.
    Kind regards,
    Tony
