Port Issue
2»
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,085 image  Zyxel Employee
    edited January 2024
    Hi @Bolzy
    Since your device is FWA510, which is a Nebula device, I assume you are using it with the Nebula control center. That's why I was asking for the organization's name and the privilege.
    Please go to Help (identified by a question mark icon at the upper right corner of Nebula portal) > Support Request > Zyxel support Access to enable and save.
    In addition, since this post is different from your problem, please check the private message I sent to you. I will help to check your problem via the private message.
    Zyxel Melen
  • Bolzy
    Bolzy Posts: 6
    I have tried to go there but the button support request it'not able.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,724 image  Zyxel Employee
    Hi @Bolzy ,
    To assist you efficiently with the issue of not being able to open ports 80 and 443, could you please provide us with the model's name of your device? Additionally, a photo of the front of or back of the device with the label would be very helpful. This information will enable us to offer prompt and accurate support.
    Zyxel_Judy
  • Bolzy
    Bolzy Posts: 6
    Hi the model name is DX5401.
  • Bolzy
    Bolzy Posts: 6
    I think that the operator Windtre had force the closure of the Port inside the firmware, could be that ? Do you think you can say me how to open It ?
