AX7501-B0 Alternative WAN port ETH
Hi!
Can you choose another WAN port instead of the SFP 10GB port.
I have looked at the manual and also looked around in the WebGui, but just got more confused. I can't seem to choose the correct wan interface. See example below.
Thanks in advance
I think this WAN naming equals the 10G port.
Hello @ALiKyr87
Welcome to the forum.
Looking at the user guide available at https://spdl.zyxel.com/AX7501-B0/user_guide/AX7501-B0_V5.15-V5.17%20Ed%202.pdf it seems like the AX7501 only has 2 Broadband WAN options: PON and Wireless WAN Cellular.
The user guide reads that you can use Cellular as a WAN backup or if the fibre connection is disconnected then cellular would be primary. But that the AX7501 automatically uses wired connection when available, see below extract.
Kind regards,
Tony
- 441 Beta Program
- 293 Service & License
