Ztp is already enabled. Please report to administrator for troubleshooting
Hello @Marcointegrated @Proxima
We're aware of this issue and have figured out the solution, please provide remote SSH via private message, and I will access the device for further action, thanks.1 -
To be able to access via ssh you need to access the VPN on our network with the ZyWALL SecuExtender application. I can provide you with the login server and username with a temporary password, then I can give you the address to log into ssh. I need your e-mail address to be able to insert it into the domain controller, once logged in you can validate the 2fa within 5 minutes and you will be inside our network.
@Marcointegrated @Proxima it's done. Please let me know if anything happens, thanks.
To solve this issue, please refer to the article below, thanks.
Thank you! But what do I need to do if I have this message:
PS C:> ftp 192.168.10.1ftp: connect :Connection refused
I have no physical access now to this device and connect now to it via ipsec.
UPD: подключившись по SSH для включения FTP сервера нужно выполнить
configure terminal
ip ftp server0 -
FTP connection was refused, SSH not connecting, console cable not connecting… what to do?
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
